CM Jerry
How many fans do you have in the chassis?
So i have cm Haf 922 and i have:
Front 200mm x 1- 700 rmp  and  120mm x 1- 1300rmp
Top 2 x 120 mm-1600rmp
Rear 1 x 120mm-1300rmp
Side 1 x 200mm-700rmp
CPU cooler Hyper EVO 212 with 2 x 120mm-2000rmp
AND those on gpu are 2x80  and on psu 1x140mm
SO answer  me pls thet i mount something wrong or is ok  by the way my cpu is overclocked on 4.67ghz  and temp is 50c!!!!
Thanks for your time
clorenz    2
Kote - what processor are you running?
clorenz    2
Kote - for that processor and speed it's not insanely high. But do you have the fans properly in the case... ie. Rear case fan being exhaust, CPU fan on the heatsink pulling air from front of case and exhausting it out the back of the heatsink to the rear of case? Front fans as intakes I hope? Just asking and going through check list is all.
yes dude on cpu i have push and pull config and rear fan is exhaust he bloing air out from case   on  front  my  2 fans are pushing   air in case   intake  ont the top 2 fans are pushing air out  exhaust  and on  the site 1 fan is pushing air out from case exhaust i hope is corect????????????
knud    126
Also, what voltage is your CPU running at? (and 50c is in idle I presume)
The side fan you could switch too air intake, but that won't be the biggest difference in the end.
no its not on idle go litle up on smae page u will se my overclocked results!!!!!!!!!
PS:ON IDILE IS JUTS AROUND 3OC DUDE but in my contry is so hot dude in my room is around 25 out is 40c :((
Create an account
Register a new account
Sign in
Sign In Now
