CM Jerry
How many fans do you have in the chassis?
world    84
ha~ha~I got you wrong!!!!!
I thought you put so many fans in the chassis... B)
Well done~
Back when I had my CM690, I probably had a good 10 case fans on it (more than there are mounts for), not counting the PSU fan, GPU fans, and CPU fans :P
knud    128
Without the GPU and PSU I got a grand total of 11 case fans. (But 3 of them are set to 0 since it's not summer time yet - and even then I hardly switch them on)
I'm using a CM690III case.
My current fans are:
Front: 200mm (stock CM fan) - intake
3x 5.25" Drive Bays: 120mm ThermalTake programmable LED fan (I placed a fan cage in here) - intake
Rear: 120mm (stock CM fan) - exhaust
Top: 120mm CM Blade Master (stock CM Seidon 120V fan) pull configuration - exhaust
I currently got four in total.
I'm planning to replace cooling solutions by:
Front: 2x 140mm Corsair SP Performance Edition - intake
CPU Cooler: Cooler Master Seidon 240M
CPU Cooler Radiator Fans: x2 120mm Corsair SP Performance Edition in pull configuration - exhaust
The radiator will be installed at the top.
Rear: 120mm Corsair SP Performance Edition - exhaust
Bottom: 120mm Corsair SP Performance Edition - intake
Yeah, thing is I have room for only 1 more fan, reason I don't have a ton of them is because the few fans I have are really large, 140, 200, or 230mm, not a single standard 120mm fan in there atm (no room for it really without replacing a larger fan, and I don't see a point to that.
CM Jerry    43
Quiet cool, dude~
The chassis you mentioned is old, so you have new one or others?
would you like to share others with us? :P
REVFER    6
Nice work Sam.
Thanks zucker  :)
Quiet cool, dude~
Thanks CM Jerry  :)
it's on progress...collecting some H/W... will post up soon  :D
Razor88    0
I have a Corsair Carbide 300R. 1 intake, 1 exhaust, 1 CPU fan (Cooler Master Hyper 212 Evo), 2 on the graphics card (Powercolor 7950 boost) and 1 on the PSU (Antec HGC 620M).
Create an account
Register a new account
Sign in
Sign In Now
