jarjar128
Can a Hyper 212 EVO fit in a Cooler Master HAF 912
jarjar128    1
HI,
Can a Hyper 212 EVO fit in a Cooler Master HAF 912? And toward what direction the fan should be, back or front?
Do you suggest the stock grease. I am not planning to overclock.
:bigsmurf:
  • Upvote 1
CM Shaun    2
Hyper 212 EVO is 159mm height and HAF 912 support max 175mm cpu cooler so it fits well.
And we would suggest to install fan toward front and make air flow from front to the back of case.(shown as attached pic)
If you don't plan to overclock then the stock thermal paste will be good enough. :wink:
  • Upvote 2
Create an account
Register a new account
Sign in
Sign In Now
