zippox
Storm QuickFire TK does not allow numpad + or enter
Undefined    0
On 3/29/2015 at 2:40 PM, Pclinde said:
Forwarded this, waiting for a response.
So, could you please give use response.
I just bought two Masterkeys pro M keyboard and have found out I can't use the numpad enter key while numlck is enabled... it's so frustrating. PLEASE, COULD YOU FIX IT?
suudelma    1
Quick and dirty fix.
I could not trace out where the other lead from the switch was connected, so I just bended it to the other side and soldered a wire to it.
https://www.dropbox.com/s/br9ydv43ys6z3d6/IMG_20170424_182738.jpg?dl=0
https://www.dropbox.com/s/ps9lhbsc36vpxlw/IMG_20170424_185341.jpg?dl=0
Screwdriver is pointing to where I used dremel to cut a trace from the board.
https://www.dropbox.com/s/d09a0waxj5040oq/IMG_20170424_193326.jpg?dl=0
Edited by suudelma
  • Like 1
Tai Nguyen    0
Hello,
wondering if there any other "software" fix for this rather than open my keyboard and doing the solder thing, since it's quite impossible to me. T..T
