DavidBloor
Aquagate Temps
DavidBloor    0
Right i have my Aquagate up and running on my P4 3. Prescott.
My temps are as follows.
Idle 32.2
Load 34.8 (Highest seen so far)
Is that about right?
And how can I be sure these are accurate, I am paranoid!
ninuhadida    0
:) those are very good temps for a prescott 8)
what i your ambient (room) temp?
if you want to be sure that the temps are good, download motherboard monitor 5 and check the temp by using the motherboard sensor, which is under the core of the cpu.
Guest Mindless Moron
the only thing putting me off buying an aquagate is that it says my case temps will rise and i want to know how much by as my chipset is at 26degrees and i dont want to push the temps up too much
Eryi    0
MBM 5 Reports On-Die Temps.
The Thermal Sensor for the Aqua-Gate has schewed temps (as do all "remote" temp sensors).
Go with the MBM temps, those are coming from the chip itself.
My temps are about 10 degrees C off from Aqua-Gate to On-Die. (As reported by my BIOS and from MBM5 on a AMD Barton 3200+)
