timinatorr
Wavemaster fan question/aquagate
timinatorr    0
Hiyas, when running games my case with the aqua gate internally mounted and stock fans, I run pretty hot - water temp reaches up to 45c (web browsing at 35c on water as a reference point). Looking for maybe case fan suggestions to get it a bit cooler. My pc does sit inside a wooden work desk, back if fully open, I keep front door open as well. I am also using a fan on the top blowing out.
P4 3.0ghz E, ati 9800 pro, corsair platinum heat spreader ram, only barely oc'ing sometimes - 3.150ghz max.
Thanks for your input. Maybe my temp is fine but to keep the aquagate from beeping, i have to always be on fan setting 3.
PS. used as4 grease on install and have double/triple checked to ensure aquagate is full.
Mr. Miyagi    2
If you're running a Prescott, and your load temperatures are 45c and idle are 35c, those are good temperatures for a Prescott.
Guest Mindless Moron
yes good for a prescott my suggestion take it out of the desk and sit it proudly atop the desk. look better and is generally cooler
